Plumbing
28 Apr 2004
I am just plumbing in a new sink and have used push fit 'Speedfit' fittings (not tested yet) and will be concealed in a stud wall.
I am also moving a couple of rads a few feet. Considering using the same fittings for them.
Anybody have any experience of the reliability for both uses. Do they leak?
they can easlily especially if you are using plastic pipe, trouble is that they only seal on a single o ring and if your pipe is scored even slightly you will not get a seal. Also before now I have pushed the o ring out of its seating with the end of the pipe :(
