i am trying to find out what different types of finish you can get ply wood sheets in i have seen it with a oak vanire finnish but cannot find it on the web as it got a spesual name.
You will be more limited in choice with plywood as many merchants now seem to stock MDF sheets instead.
I live in M/cr too and use Arnold Laver(timberworld) Irlam. Here is a link to their sheet materials page,which may help you. http://www.laver.co.uk/results.asp?catid=3
No offence meant, but if you do a search you are looking for veneered or faced ply.
For inside and dry use MDF is OK and easier to work with than ply.
small world !!! i use arnold laver in Irlam/cadishead , and can recommend it .the veneered MDF range is excellent, they can also deliver if you need , about £10 locally ., off the top of my head
I hope that Lavers in M/C is better than in Sheffield or Chesterfield. I found them to be very expensive and hopelessly inefficient. When we stopped using them a few years back I had David Laver on the phone telling me everything would change if I gave them another go, so I gave them another go and they b*llsed up the first order.
If you are looking for veneered ply I would phone round local timber merchants for the best price. Even Travis Perkins should be able to get it in for you.
