I'm building a tiled worktop for a kitchen island and using 9mm, hardwood faced, plywood for the base. On top of this I am laying 300mm x 300mm porcelain tiles, (6mm thick if I recall correctly).
There will be no taps/sink fitted in the island. It will basically be a food prep area used for cutting veg, peeling, mixing etc. I am planning on using a waterproof adhesive and waterproof grout to finish. Do I need to seal the plywood surface first?
I will be fitting a 90º edging strip to cover the edge of the plywood but did think about giving the edge a coat of pva beforehand as an additional protection.
