- Joined
- 10 Jun 2018
- Messages
- 19
- Reaction score
- 0
- Country
I have a wooden outbuilding on a concrete slab base
The roof is pent and has quite a fall towards the back, with guttering
On this side, where the painted ply wall meets the ground, leaves accumulate and water splashes, resulting in the bottom of the ply (between 1-3 inches) getting wet and rotting
I was planning to address by using a wet rot hardener, expanding foam to seal the small gap along the bottom, and then bostick wide flashing tape to do a ‘L’ shape along the bottom of the ply wall and along the ground to stop further water penetration
Another idea was to lay a row of say 3-4 high bricks butted up against the ply wall as a more perminant solution, is that even feasible to do and have cement in contact with ply?
The issue is that the bottom of the joists will still be in contact with the slab but this edge seems to be the one with the issue as it’s beneith the guttering
Any thoughts on my ideas or suggestions how to tackle?
