- Joined
- 4 May 2007
- Messages
- 53
- Reaction score
- 0
- Country
Hi Folks
I've just moved house and would like to fit a new CU at some point in the future once I'm qualified. At the moment we have an old MEM fuse box on a TT system.
There's a PME connection available but not a Main Earth Terminal that I could connect to. i.e the main fuse would need to be pulled in order to access the PME terminal. Obviously, even when I'm qualified I won't be allowed to do this.
I've spoken to my local supplier to ask them what the procedure is for connecting a new CU to the PME. I assumed they'd want to check that the bonding has been upgraded etc and would then take a 16mm cable from the PME terminal to an MET for me to connect to but they said that this was the electricians responsibility. I then explained (again) that the main fuse would need to be pulled in order to access the PME terminal. They then said that an electrician wouldn't be allowed to remove the fuse. The conversation then went round in circles for 10 minutes before I gave up. I did ask to speak to someone in their "technical department" but they said they didn't have a technical department "as such"!
Can anyone enlighten me as to what the correct procedure is and does it bear any resemblance to what happens in reality. Am I being nieve in wanting to do things by the book?
Thanks.
Thanks.
