I would like some advice on replacing some pneumatic time switches.
The current set up is as follows:
There is one light at the bottom of the staircase/corridor and one light at the top of the staircase.
In the corridor at the bottom of the staircase there are two of these switches.
http://www.elkay.co.uk/product.asp?id=1&catid=1
At the top of the staircase is a single switch of the same type
The two switches at the bottom of the stair case are wired as follows:
Switch 1: located at the entrance to the hallway at the bottom of the stairs has 2 lives going to the com terminal and two switched lives going to the NO terminal. The circuit uses 2 core wiring so the NC terminal is left empty.
Switch 2 located at the bottom of the stair case is wired the same as switch 1
Switch 3 is located at the top of the stair case. This switch has a single live going to the COM terminal and a single switched live at the NO terminal. Again the NC terminal is left empty.
Any one of the three switches, when switched on will turn on both lights in the stairwell for the programmed time period
I would like to replace the 3 switches that are currently fitted with one of these:
http://www.tlc-direct.co.uk/Products/DNTLSW10ILM.html (master switch)
And two of these
http://www.tlc-direct.co.uk/Products/DNSS1SL.html (slave switches)
My question is will the current wiring arrangement dictate where I will be able to put the Master switch?
I would like to put the master switch at the top of the stairs in place of switch 3 as there are no windows to provide any natural light but im not sure if this will affect the operation of the two slave switches?
Would any one be able to advise on whether i can do this or not?
And two of these
