poerful shoer up int the attic conversion
3 Feb 2009
Fife
hi all
i am in the midst of putting an attic conversion in but w0uld like a very very powerfull shower of some description fitted but due to changing to a condensating boiler on the ground floor i would really appreciate any advice you guys could give to achieve a mega pwerful shower.regards trevor
Combi condensing boiler, or traditional heat-only condensing boiler?
hi
it is a worcester bosch 42cdi condensating boiler.
regards trevor
All boilers are going to be condensing (not "condensating" as the terminology is incorrect).
So you are going to have a combination boiler. In which case, what is the water pressure like - if it is good then this will be all that you need for a strong shower up there as it will be mains water pressure.
