polished cast iron cleaning advice
5 Mar 2006
West Midlands
moved into 6 months ago and have a fireplace with a polished cast iron back plate and a granite hearth. What's the best method/products for cleaning these and getting them shiny? I tried a bit of general polish in one corner and it went rusty brown! fortunatley a bit of wd40 cleaned it off. I'd like to get the polished plate as shiny as possible, as it looks a bit dull. Also, the granite hearth has been stepped on by kids and it too looks drab. I have noticed that just wiping it with a dry cloth does leave a bit of a streak. should I use a special cloth, or brush or something?
any advice would be appreciated.
seneca - you need to use Zebo, a polish formulated for CI fireplaces & grates (it used to be called Zeebright). It comes in a tube (like toothpaste) and is applied with a brush (like a shoe polish brush), left to dry (5 - 10 mins), then buffed with the brush; a final wipe with a cloth ensures a polished/burnished finish. Wear rubber gloves, spead some old newspapers, keep it away from the wallpaper, 'cos the black Zebo will mark everything.
Granite hearth - use a granite polish made for kitchen worktops.
Both the Zebo & granite polish available from supermarkets.
thanks symptoms. So, even though it's called "black zebo", it can be used on the chrome looking cast iron? I heard that with the specialist polishes, you have to keep polishing every couple of weeks, or else it's not worth doing. Is this right? what happens if you don't? I don't mind every 2 weeks, so long as it's not any more frequent than that.
if its chome looking (silver / mirrored finish), then black anything wont look that good will it?
hence, why I asked; just to be sure. I thought it might need to be wiped off to leave the surface polished. I have used white polish on black metal, and that can be wiped/buffed to leave the surface shiny. Never hurts to make sure, particularly when new to something. Hence, my asking in the first place. I did mention it was chrome in my original post, so maybe zeebo is not what I need. Thanks anyway.
I too have a polished iron fireplace that needs something to return it to its original appearance. Did you find out how to clean yours? I've burnt a variety of stuff in my fire such as wood and fruit debris and this has left a sticky sort of goo around the edge. :rolleyes: HELP!
Bit late now, but polished casts are NOT recommended for solid fuel. WD40 helps keep them clean, but the Zebo might help, now it is discoloued
I have a fireplace showroom in Potters Bar. Our cast insert suppliers recommend that polished inserts are only suitable for gas or electric use - all Black inserts are advised for solid fuel use.
If the polished cast tarnishes or rusts, a metal cream cleaner such as Hotspot Cream cleaner will remove minor tarnishing applied on a duster, but if this is a heavier tarnishing you will need to apply it on a 'brown scourer pad' with a bit of elbow grease.
Zeebright or Black lead is used to renovate Black casts which have been leaded originally - beware as most modern casts are sprayed.
