Ok, hopefully one of you guys will be able to help.
I have a 1999 Polo which has started giving me a problem.
When im coming to a stop i will put the clutch down and apply the brake. The car will then do one of two things,
1, The revs will drop very low and they feel 'lumpy' and 'rough'-the stall battery light will flick on as though the car tried to stall but caught itself. If it catches itself it is fine and sets off fine.
or
2, The car will do the above but cut out/stall.
As you can imagine, the car stalling nearly every time i come to a stop is a bit of a problem
I havent done anything with it yet as not had time but thought i would ask for a few idea's before i did so as i might have an idea of where to start. The car does burn a little oil, not a lot but requires topping up every month or so. The Ht leads, plugs and dizzy cap were all new about 10 months ago as was the oil filter.
I was thinking maybe a sensor could be to blame? Any suggestions welcome.
Regards.
or
Regards.
