Hi all,
Having repaired the corner of my summer house(see other thread) and decorated inside and out.
The blooming roof has stared to leak rather badly.
There seems to be no damage to the felt but the roof is sagging in the middle quite badly so I guess the water is pooling there (it was dripping slightly this morning even though the felt was dry on the outside)
I know the roof needs replacing.
I was thinking of going for a 10mm double wall polycarbonate sheet.
At the moment the roof is vgroove cladding 12mm thick which sits on a frame which sits on the outside of the summer house. The summer house isn't square but a square with a corner cut off if that makes sense)
I was hoping that I could get one sheet of polycarbonate 2500 x 2100mm but the maxiumum size of the frame is 2100 so there would be no overhang, which I suspect would cause a problem.
Any reason why I could remove the frame and fix it straight to the walls?
Or would I be better going for 2 sheets of 1220 which would give me a large overhang?
http://www.nick-gray.co.uk/Polycarbonate_Sheet/10mm_Twinwall/10mm_BORG?product_id=1120
Are there any issues with using Polycarbonate?
thanks in advance
thanks in advance
