Technically you need a drill with a much shallower tip angle than conventional......this isn't the easiest to achieve, so try using a lubricant such as paraffin when you drill.
John
Get a 'FORSTNER' BIT SET.
Cheap as chips- you do NOT need a expensive set --lots on ebay I'd bet.
Spray a bit of WD40 on before you drill- and DONT press to hard on drilll- let the drill bit do the cutting.
ps-- remember- P Carb is very thin- and after penetrating the first layer--go slowly down to the 2nd and then the 3rd and maybe the 4th layer.
Easy peasy lemon (sooey) squeezy..
Thanks for the advice Since posting I have picked up a bosch bi-metal 14mm hole saw, it has relatively small teeth so I will give this a try and let you know how it goes.
