polypipe in notched joists
14 Sep 2013
Yorkshire
Hey if running polypipe in notched joists and fixing with nailing clips will it cause noise through expansion and contraction as the heating goes on and off or is that just with copper pipes?
Is it not advisable to use nailing clips to clip to the notched joists then?
is using nailing clips to clip the plastic pipes to the notched joists ok then?
does plastic pipe expand more length ways than expand in diameter. So using nailing clips to fix the pipes to the notched joists may not be as much of a problem as with copper?
nail it if you want, the expansion is primarily linear and the pipes will therefore sag in between joints when warm. Personally I would only secure where necessary to prevent it jumping out when replacing boards.
ok so if I just clip it sparingly i.e not as it passes through every joist I should be ok?
