Hello Chaps,
I'm after a Polypipe UFH manifold and would like to use 16mm pipe as i have quite a bit left over.
I hear the brass unit will be disconnected very soon, the stainless steel ones are 15mm push fit connections. Is it possible to use some sort of an adapter and remove the pushfit fitting and replace it with a compression fitting which allows me to use my 16mm pipe?
Looking to buy this -
https://www.tradingdepot.co.uk/poly...-stainless-steel-under-floor-heating-manifold
Thanks!
Thanks!
