C
Coniferman
Zanussi DF56/45 10+years old.
I recently took this out of its very tight 'home' to give good clean etc. I found a big piece of polystyrene surrounding the freezer section compressor (it has 2 compressors) with a big "remove before 1st use" sticker!! Ho hum! It is likely the 1st time it has been taken out from its position. It was included when I bought the house. The freezer section still works very well by the way! Obviously I removed this polystyrene.
Under the top metal lid (above the fridge section) is another large sheet of polystyrene which is loose. I would have to remove two screws to lift the lid and remove this polystyrene. I assume this one is supposed to be there though to help insulate the fridge???? I am just wondering if this could also be packaging and supposed to be removed though too? (It could have been to prevent the lid from being crushed pre-install?) I can see that the fridge would be more efficient if warm air had the entire lid to convect heat away??
Can anyone confirm if this is packaging and should be removed as with the stuff around the compressor or is it meant to be there?
Just that the fridge is currently marginal in terms of performance and the compressor is nearly always on but increasing ventilation (or using a fan to blow air down the back) improves performance greatly.
