Polytank loft tank - 22mm hole saw
18 Jan 2008
Staffordshire
About to fit a 50 gallon polytank in the loft. Instructions say I need 22mm, 27mm and 29mm hole saws. Plumbers kits have the 22mm and 29mm, but I can't see a 27mm anywhere. Not even as an individual item.
Any suggestions?
Ant
try B&Q they sell various hole cutters if you can get 27 then a 25 or 26 will cut the hole then carefully open it out with a stanley knife.
I was prepareing an expansion cistern, and I'm pretty sure it was the 27mm I was short of. I visited my local 'hardware' store, the tools department, and bought one there fairly cheaply.
An Imperial size cutter would be the right size. 1-1/16" = 26.9875mm, which is close enough to 27mm for most jobs.
IME hole saws tend to cut oversize anyway - generally, the cheaper the hole saw, the wider the tolerance.
To open out a fractionally undersized hole, my weapon of choice is a half-round file.
