pond building
18 Jul 2012
Sussex
hi there, i am thinking of building an above ground koi pond, the dimensions of which are 10 x 7 x 5 feet. I am looking to use breeze blocks but i am unsure of which is the best way to build with them, either as a brick and use two skins or lay the blocks down flat ? Has anybody any experience of this and have any advice ?
thanks in advance.
Well I take it 3' will be below ground? so definitely 9' flat down. Above ground you could do block upright on the inside with brick on the outer skin.
