Can anyone advise on how to calculate the pump flow rate required to pump the amount of water from my lower pond to the upper pond, to replace the water which has flowed out over a waterfall into the lower pond. The two ponds completely separated and the waterfall, a block of sandstone, hangs over the lower pond allowing water to flow from the upper to lower pond. I hope this make some sense and thanks very much for any help.
