ive been trying to get these pond pumps to work and its not happening for me.. probably a simple answer to it.. the circuit is: An RCD plug with a 3 amp fuse in, 2.5mm artic cable coming from that to the outside through conduit into a junction box. from that there is 3 x 0.75mm.
1 = and independant pump
2 = a second pump
3 = a uv
( the second pump and the uv work together)
so what i did is try each circuit on there own to see which one was tripping them out..
pump one tripped as soon as i turned it on, then tried second pump and uv together they worked, so presumed it was the first one tripping it all out.... 15mins later the second pump tripped out and the filter box was empty??? tried it again tripped out, filled the filter box up with water and it ran til was empty again... so neither of them seem to work. power is obviously getting to it. i thought the rcd plug must be nackered (i havent changed it to check) but why would it work for a bit for one and not at all for the other
its ran perfectly fine for a few years... i have no test equipment btw.
any ideas or answers would be great.
2 = a second pump
3 = a uv
