We have a garden pond and we want to fit a filter system.
The filter is supplied with water by a 240 volt pump which is submerged in the pond and then returns by gravity.
The filter and the power source are both inside a conservatory out of the weather. The pond is about 3 metres away from the conservatory and the area between is a concrete patio which as been overlaid with decking.
Would the 240V power lead to the pump be OK just lying on the concrete(under the decking)or does it need to be buried or put in a conduit?
The makers of the filter and pump (Oase) also suggest it be fitted with one of those breakers that you would use with lawnmowers etc, which plug into the socket before an extention lead. The house was rewired last year and the socket I want to use is the outdoor type with a lid that closes over a plug so there isn't room for a plug in breaker, don't the breakers in the consumer unit protect it all anyway?
Many thanks.
Many thanks.
