i there
i have a water feature with a oasis aquashift pump, when you swith it on the pump trys to work but does not pump the water,if you lift the pump out of the water and then place it back in the water,the pump works well and as it should
if you then turn the pump off and then on again the same thing happens as above
has anyone any idea why i cant get it to work properly all the time
Ivan
Ivan
