Hi All
I recently had a crack at building a water feature. A rectangular, above ground pond (6' by 3') with a wall up the back with a blade, waterfall fountain.
The problem is this.....
The outside wall is a brick skin which is slightly higher than the internal block skin. Over the edges of the blocks are draped the underlay and pond fabric.
The inner layer is still slightly lower than the outer brick skin with the fabric laid over it....How can I level them up so I can lay the travertine stone edging down flat across both the brick and liner?
I'm stumped...I did think of trying to board up the inside of the pool and then pour self leveling cement mix around the edge...but because the liner and underlay are flexible...I thought this might just crack when weight was applied...
Need help....it's driving me nuts.
many thanks for sane advice in advance : )
