Poor Hot Water Pressure
27 Jan 2008
Yorkshire
With a new bathroom suite and modern taps we now have poor hot water pressure.Piping is 22ml to point of entry of the taps.The system is a conventional system with Hot Water Cylinder and a 42 gallon tank in the loft approx 60 inches above the base of the cylinder. I don't want to fit a pump if I can avoid it.The other options are to lift the tank to the maximum height (another 20 inches) or would it benefit if I fitted another tank in tandem?. Any advice appreciated !
are the taps high pressure taps ? if they are this is the problem .... quite common nowadays. always check the instructions/box before you buy. easy mistake to make though!
Most likely cause is the tap design - are they designed for low pressure systems?
If they are not, it may be possible to fit high flow cartridges / internals
Have any isolators been fitted in the pipework - if so are they full bore or cheap and cheerful - check that all the valves/isolators on the runs from the cistern and cylinder are fully open.
Raising the cistern by 20" will probably not have a noticable effect.
Adding another cistern in tandem won't increase the pressure
If the taps are the main reason for poor flow then I'd start there!
Just a quick thought - is the poor flow only from the HW?
If it is, is the HW flow at the kitchen sink any different from before the new bathroom. If it is then re-check any gate valves supplying the cylinder - not unusual for them to jam partially open/shut.
Hi we have checked all the obvious pottential for faults.The taps are supplied from PJH (B&Q).As you state I think the fault is in the moder slim design.I have contacted PJH who stsate that their are no restrictions viz low/High pressure requirements.They did send a repacement tap set which has made no differance,so I presume that the only answer will be to fit a pump (Or change the wife and go back to traditional taps!)
Given that it seems 99% likely to be the tap design,will a pump improve the flow?
would be easier to just fit new taps (low pressure ones). cheaper thans a pump, quicker and easier to do. saying that it's your call.
:D THanks for the replies. Given that the Bath Tap set is 4 parts,Spout,Diverter Valve,Shower Head contol and Shower Head I think it'll have to be the pump-Thaks for your help much appreciated at least I haven't wasted my time lifting the tank 20"
