My daughter has recently moved in to a small 2 bedroom house with a four year old central heating system. The boiler is a Worcester Bosch 24i and all the radiators were replaced as well. I have just removed disabled wet room equipment and re-instated a bath connecting up to the original capped 15mm pipework. I left the Mira electric shower in place. She tells me that when running a bath the hot water isn't hot enough for "a nice relaxing soak" The basin and kitchen sink water is adequate. The handbook says the water temperature is fixed at 55 degrees C and cannot be changed.
Has anyone got any ideas about increasing the temperature of the water? 55 degrees seems a little bit low to me. Is this now the norm with modern condensing boilers? Surely, a modern boiler should be able to supply hot water for a bath or has the "green brigade" taken over!
I welcome any replies
