We have a water on our allotments with MDPE pipe which is 22mm.
The supply runs slightly down hill from the supply. At the bottom of the supply the pressure is pretty decent, at the top end near the supply the pressure is useless and has got worse over time.
When a tap is on at the bottom of the supply you would think the water is off.
Supply is turned on fully on etc.
Can anyone suggest what might be causing this? as we are at a complete loss as what to do and being an allotment funds are fairly tight
