Excuse my lack of correct terminology here, but I have a toilet that does not flush correctly. Sometimes you get a proper flush, other times you get an attempt but not enough water flows into the pan to cause a full flush. Subsequent flushes (after a failure) just result in small amounts of water flowing into the pan.
I've taken the top off the cistern and it is filling OK and the float is working OK. The exterior handle is attached firmly and pulling the level internally. It seems as though there is a suction problem and the water is not getting into the central chamber? Are there any seals I should be checking or is it a case of replacing the central chamber?
