- Joined
- 14 Jul 2004
- Messages
- 5
- Reaction score
- 0
- Country
Hello all, I wanted to ask some advice on water pressure and the best solution for me. Here's the problem:
I have a top floor flat (4th floor) with my own Cold Water tank and Hot water tank in a cupboard.
Everything (water and central heating) is on a gravity system and the bottom of the main tank is about 5ft from the floor on a metal frame (with Hot water tank underneath).
Cold Water to kitchen sink is mains, everything else is from gravity system.
I fitted a new shower and used the existing shower pump that was in the flat, so this works fine.
The boiler is an old (20 years) boiler, not a Combi.
The problem is with the kitchen and basin taps/toilet. I think I made a mistake (twice ) in that I bought the wrong taps which operate at a higher pressure than I have available.
I wondered what my options would be to improve the situation.
As I see it:
1. fit a Combi - too expensive for me.
2. replace taps with low pressure ones - again, will be expensive when considering I've already got 2 pricey taps and would have to get 2 more.
3. fit a 'booster' pump - I don't know much about this option, which is why I'm here. Is this a possible fix? What would I need to consider? Would it put strain on the boiler? Would I have to remove the shower pump? Anything else I need to think about?
Alternatively if there's a better solution than any of the above could someone advise me.
Thanks in advance,
Neil
As I see it:
Thanks in advance,
Neil
