Had a pop-up waste installed by plumber a while back, and it's never really worked properly.
The lever is built into the tap, and feels really loose, always returning to a central position whether you pull it up or push it down.
The actual plug bit only moves a couple of millimetres even though the lever only moves a couple of centimetres.
The plug doesn't hook onto the horizontal bar connecting the lever to the plug - it just has a flat foot plate that rests on top of the bar.
If I tighten the ball joint nut then I get no real movement, but if I loosen it then the whole thing goes wobbly and the plug doesn't move at all.
Any help welcome,
Cheers
Any help welcome,
Cheers
