Without thinking too much about it we bought these tiles, and now I realize we might have made a mistake:
I am going to use them to tile the splashback of my kitchen. Right now there are small ceramic tiles, which I will remove and replace with the new ones.
The wall is a party wall (masonry) and I assume is plastered... which I've just figured might be a big problem.
If I got it right, the weight limit for plastered walls is 20kg/m2, my tiles should be 20.6kg/m2 excluding grout and adhesive (so probably around 23-24kg/m2 in total?)
For the adhesive I was thinking about using the Mapei Keraquick Wall & Floor Rapid-Set Flexible.
Is that going to be a huge problem? I am not tiling the whole wall, the highest I will go is 75cm behind the cooker and about 48 in the rest of the wall. Is this really likely to be an inssue?
Maddox Grey Concrete Effect Porcelain Wall and Floor Tile | TileMountain
Achieve an industrial-chic look with Maddox Grey Concrete Effect Matt Porcelain Wall and Floor Tile. Stylish and contemporary.
www.tilemountain.co.uk
