porcelanosa 1m long ceramic tile...cutting problem/help
23 Jun 2007
Derbyshire
Hi all,
I have bought some tiles 1m long from Porcelanosa which are glazed just on the top...ie slighest knock and they chip.
I have spent ages trying different techniques on cutting these tiles.
I have a rubi tile cutter that when i score the tile from the front chips it...so tried cutting the tile from the back which does work if you are cutting enough off the tile..its when you try cuuting the 1cm off thats the problem.
Tried the rubi electric cutter...chips it again...from either side cut.
Tried diamond disc in hand held 4" grinder... chips from front but do it from back not all the way through and then break it and its a hit and miss and as these tileswork out about 18.00 EACH I cant afford to make mistakes.
I want a nice clean perfect edge???
Any help /advice from you pros out there would be appreciated
Hell of a tile though to work with ...ie in size to cut, easily damage etc...but will hopefully look lovely if I finally get any on the wall.
thanks
£18 per tile, you must either be made of money or bonkers.
To engage in a project that involves singularly expensive products such as yours, also requires the tools that can deal with such expensive products.
It would be like buying delicate hand made ceramic antique tiles and laying them with a lump hammer.
Either get something cheaper, get a pro' on board or get real.
Are they the flat gloss white ones (Marmi blanco), I've used the smaller 600mm ones they do in the same range before and am using them now.
I find you need a brand new wheel in a manual cutter and very light pressure when you score it. Thats using a TS-700 plus
Jason
