porous hot water tank
20 Dec 2004
Hello all
I just fitted a new bathroom and had to do some pipe work near the hot water tank. I must have moved the inlet pipe somehow and now water is very slightly seeping through the tank wall, not from a joint, but through the tank wall about an inch above the inlet.
Beside changing the tank (not enough money right now) as anyone got any suggestions for a repair?
Thanks in advance
DDAS said:
Hello all
Thanks in advance
no chance mate. the tank was likely corroded. Just count yourself lucky that the whole thing didn't rupture and flood the house ;)
No guarantee, but if you can dry it all out and then solder over the area - use type D to make it thick, you might stop it for a while.
If you've never used stick solder (type D) , read about it and practice first!
sorry for the late reply. I got shut of it and put a new one in.
