Porous render
6 Jan 2005
Hi Guys/Gals
Anyone help?
Just rendered the outside of a workshop. Single skin hollow concrete blocks. Used 2 coats, scratch and top. Put the water proofer in both coats. Scratch coat about 5 to 8 mm top coat the same. The building is in a very exposed part of the southwest and although I finished it about 2 weeks ago it is still porous. To be fair it has hardly stopped raining since I finished. When the rain comes, along with the wind, it takes about an hour and you can see the blocks starting to go that horrible dark blue damp colour, starting with the perps and joints and eventually the blocks them selves.
Question is, am i being too hopeful for an instantly waterproof render.
Will it become waterproof as it cures and if so how long will it take.
Also when it does dry out in the spring will an ordinary exterior paint be enough to seal the wall. I have noticed other buildings in the area have slate tiled the sides of their buildings.
Should I wait or do i need to do something more serious.
Cheers for any advice coming
Hank.
Years ago people used to put slates on the side of buildings and also render over them as a damp proof barrier ,I think you will be better off giving your workshop a few coats of Crown Stronghold or Dulux Weathershield, I would put three or four coats on .....Just noticed your address is in France so find a good exterior paint if you cant get the other two ;)
