I am about to embark on the conversion of my landing into a small 4th bedroom (8' x 6'). This will contain a built-in, enclosed, cabin bed which will make the existing light switch difficult to access. Wiring a new switch is no problem as loft access is easy and the new cable can be brought down through the new stud wall. The problem is that the side panelling of the bed will come right up to the edge of the door frame leaving no space for the switch. I cannot chase it into the adjoining wall as this will be covered by the open door.
Is it acceptable to mount the switch in the side panel of the space under the bed providing that the rear of the switch is made inaccessible. i.e. treat the panel as a wall and box in approximately 1 foot of the under-bed space to create a void.
Other options would be a pull switch or some sort of remotely operated unit based on the existing switch (which would still be accessible for maintenance).
What would you do? Any suggestions welcome.
