I'm out with my tape measure trying to decide if a new boiler can be fitted in a particular location. The problem is positioning the flue terminal outside.
With the minimum clearance from an internal corner (450mm?) it would be too close to a doorway (<300mm). If I go as high as possible whilst maintaining the clearance to the internal corner I still can't get it 300mm above the top level of the door, but it would be 400mm away diagonally from the top corner of the door opening. i.e. the closest part of the door opening would be 400mm from the flue. Question is, would this be ok?
