I have fitted a 1.5 bar positive head shower pump .it is fed by cold water tank and teed off hot water from cylinder.the pump is fitted on floor in cupboard next to cylinder. The shower head is 400 mm below cold water tank.the problem is the pump will not kick and work.Is this due to lack of flow from tank ? Or do indeed a negative head pump? Any help will be invaluable !
