Hi every one
My traditional central heating (an Ideal Classic boiler aged 15 years, a hot water cylinder in the cupboard, a Honeywell thermostat and timer/programmer) has been working fine until a few days ago when the heating suddenly stopped working and there was no response to the stat.
The hot water was working alright. The timer and stat were OK.
The cylinder and its stat, the pump, the three way diverter valve and the electronics PCB board were replaced 3 years ago.
After some experimentation we discovered that the heating worked only when the hot water was on, the stat was high and the heating program/timer was on. When we turned off the hot water the heating stopped immediately.
When we turned off the heating program/timer then no heating worked despite hot water was on.
I checked the little lever in the diverter valve and it moved easily without resistance.
I got very much confused as I read various forums about similar valve issues and now I am not sure what to do now. A gas engineer or a plumber or electrician?
Please advise.
Please advise.
