Hi
Any help with the following would be very much appreciated.
The basic problem is that when the hot water is on (at the programmer and demanded by the tank thermostat) then if the central heating switches on it cannot be switched off.
I have a siemens RWB9 programmer
Two Danfoss HPA2 valves
A wickes room thermostat
A British gas CS1 tank thermostat
And a v. old BAXI boiler
If the hot water is off (at either the programmer or the thermostat) then I can switch the central heating on at the programmer and then when the room thermostat is turned on I can see that the CH valve opens (the manual override bar moves freely) when the room thermostat is turned off I can then see that the CH valve closes (the manual override bar now requires force to move it)
If the hot water is on and demanded the HW valve opens and if the HW thermostat is turned down the valve then closes.
I.E. everything seems to work fine.
However if the HW valve is open then it is not possible to close the CH valve except by turning off the demand for the HW
I thought this was a problem with the programmer so I have replaced it with a Drayton unit but the problem still persists.
The problem could be wiring (and we have only recently noticed it) or could it be a problem with one of the valve actuators.
I have tried to match the wiring to the Honeywell guide listed in other posts and my system would seem to match the Sundial S plan (with a two wire thermostat) although it is not obvious whether my wiring matches the S plan wiring
Is it worth swapping the wiring for the two actuators to see if the problem reverses? Or is the system behaving normally
Many thanks for any help you can provide
