I left a fence post lying down on the grass over the ridiculously hot weekend, then last night I decided to move it back to where I've been storing them (will be fitting them shortly). When I picked it up and looked down th barrel of it, it was quite badly bent out of shape - and it was bolt straight when I bought it as I checked them all thoroughly.
Should this happen - is this typical of leaving posts lying in the sun all day (the same has also happened to some gravel boards I have)?
Will the posts do the same when they've been erected? Will wood preserver/protector do anything towards minimising this? The posts are planed and reeded if that makes any difference.
Thanks in advance
Thanks in advance
