I am pretty sure i am going down the route of fitting a accumulator / expansion vessel to increase the flow rate at my property.
After searching and reading on these forums I still am not sure about a few things, and any help would be appreciated. Sorry i do have quite a few questions!
My house is a 4 bed with 2 bathrooms.
1) I think i need a 500 Litre Vessel, does that sound about right?
2) I was hopeing to put the Vessel in the same small room as a new boiler, but that room gets quite hot. Will this mean that water in the vessel will heat up so i will struggle to get very cold water to the taps?
3) With question 2 in mind, will i get a problem with condensation?
4) I assume that quite simply i could plumb in the vessel after the stop cock and then supply the house from there through a flow reducing valve?
5) I have priced up 3 vessels does anyone have any idea which would be the best or another they could recommend? GAH Coldstream 500 £1045 inc vat, Altecnic Ultra Pro Expansion Vessel 500 £760 inc vat, and Reliance Water Controls 500 vessel £1000 inc vat.
6) Finally does any know what sort of maintenance cost or routine is required for one of these vessels?
Thanks,
Rob.
Thanks,
Rob.
