- Joined
- 25 Jun 2007
- Messages
- 6
- Reaction score
- 0
- Country
My boiler was fitted with an old external timer and I had a new internal one installed on the circular bat on the front. The old timer was left in place and I decided to remove. I removed the timer and used a connector to bypass where the timer would have been in the circuit and attached the wires accordingly (I left the switch wire out). I had tested this and it worked fine. However, the second time I tested the boiler switch wire made contact with a metal appliance which caused a short. Now none of the boiler status lights illumate and the machine doesn't work.
I've replaced the 2A mini fuse and installed a new 3A fuse on the plug, but fear something has blown on the PCB. I'm guessing that an electronic part close the point of entry has gone. Any ideas?
Cheers
Cheers
