Hi, hope somebody can help with my boiler problem.
Called a Corgi engineer to service the gas fire and my Potterton 10 – 16 Netaheat Electronic (serial number GUK127942).
The reason for calling the engineer is that the radiators take more than one hour to become reasonably hot – they are never too hot to touch even if the heating has been running for ten hours, as a result the house can take 2 to 3 hours to become reasonably warm.
The engineer found that the pressure taken from somewhere on the gas valve could not be adjusted above 8 bar – but could be turned down to 6 bar. The burner and data sheet inside the boiler electrics cover states the max pressure should be adjustable up to 12.3 bar.
The engineer took a pressure reading of 21 bar at the main gas feed.
Looking at some other threads - mention has been made of the boiler control circuit board ( type 407676 serial number M136515) and the voltages for the gas valve, which are:
T1 – 225 V
T2 – 150 V
T3 – 0 V
The engineer informed me that he would need to find out some more information and would return at a later date – that was four weeks ago.
Could anybody throw any light on the problem before I spend more money on a different engineer.
All help greatly appreciated and many thanks in advance, Spruce.
T1 – 225 V
T2 – 150 V
T3 – 0 V
