potterton 100 hot water problem
25 Nov 2005
Liverpool
Hi, hot water problem is when turn tap on boiler does not ignite if i leave it running after about 5 6 mins boiler will eventually light will stay on until i turn tap off, but it central heating is on then turn tap on fires up and have hot water until turn tap on bit puzzling Thanks to all
A.P.S Tube split,venturi on fan box blocked are a couple ;)
DHW diaphragm or microswitch worn and not operating correctly.
