Hoping this can be a simple yes answer!!
I have a problem with the hot water supply from the potterton 24 (not the HE model)
Heating works perfectly, no problems there but when hot water side is operated a number of things occur
1. No hot water!
2. boiler operates briefly
3. gurggling noises
4. pressure gauge increases and reads erraticly
5. central heating flow pipe gets hot up to a meter or so from boiler
6. boiler shuts down
As its attempting to issue heated water along the central heating line, but without the pump operating (thus giving heat along the short section of flow pipe) and the noises/ pressure increase/ boiler shut down, would this point to the 3 way valve not switching/ sticking? If so, is this part stripable or replacement only?
1. No hot water!
3. gurggling noises
