I've got a Potterton Promax 15 HE condenser boiler, and the pipe that drains the condensate from the condenser trap is missing (long story short: stepdad fitted new kitchen and threw away original pipe connected through old worktop!). The water has been draining into a bowl kept underneath since then, which I empty regularly. I've had 2 BGas service inspections in the 2 yrs who commented on the missing pipe but merely to say 'you should get that replaced'.
Last w/e I had another prob with the boiler (air in the system causing the heat exchanger to be extremely noisy) so BG came out (covered by service agreement) and repaired that, saw the missing pipe, made a phone call (like the 2 prev engineers before him) and decided it was too dangerous to leave and so has isolated the supply to my boiler leaving me with no hot water or heating!! Luckily have elec shower upstairs and d.washer / w.machine both run off cold supply only.
BG estimated £200 to source and replace pipe, but when I called Potterton to get the part # to buy it myself, they said it's not a specific part, can be bought from ANY plumbcentre. Even the whole condenser trap kit (which ISN'T missing) is only £32!!!
My quandry now having seen a few old posts about where the pipe should drain to. The original just went into my waste outlet (same as d.washer and w.machine in my under-sink cupboard). Is this OK??? BTW, it was BGas that fitted the original boiler 5yrs ago and ran the pipe into the waste outlet so if that isn't correct then I need to start shouting at them to get them to take responsibility for fitting it wrong in the first place...
