Potterton Profile 60e, fanned, balanced flue boiler
PROBLEM - Boiler starts with fan for about 2 seconds then stops then fan starts again then stops. This cycle repeats perhaps four or five times; eventually fan remains on and ignition sequence starts - all is then well until the next time the boiler has to start up again.
I suspect a sensor somewhere - does anybody have any ideas? In the past I have found several poorly soldered joints on the pcb leading to intermittent operation but this present fault does not seem to be related to that. I have tried increasing the water pump speed without any effect.
Philip
Philip
