I have got a Potterton Puma 80 permanent pilot light boiler, its about 7 to 8 years old. For the past couple of weeks i have noticed that the flow out of the hot water taps has been very low, so low in fact that the boiler stops firing whilst the hot tap is open, then after about 10 seconds or so the boiler fires up again. I have measured the flow rate out of the taps and it is 4 litres per min, i think this is too low the manual says that the DHW switch is set to 10 L/min. I thought i would try turning the taps on upstairs whilst the down stairs were on just in case of an air lock, unfortunately absolutely nothing came out of the top taps until i closed the bottom taps. Please help! Is it the DHW flow switch/limit switch? what should i be looking for? or can the boiler have caked up with scale and crud thus reducing the flow of the water? Though this would suprise me as the CH seems to work fine.
Thanks Dave
Thanks Dave
