Hi, I moved into a house last year which had a Potterton Suprima 50 Combi Boiler installed.
From day 1 i have had the same problem, the boiler cuts out when heating water.. The Central Heating works fine and there are no issues if just running that but when it tries to heat water it will ignite and work for a few minutes/seconds depening on how it is feeling then cut out with the Red LED flashing. It is as though the water temp has got too hot and the boiler has cut out, however you are lucky the water is luke warm.
The problem is steadily getting worse and was wondering if anyone had any advice.
