Hi all
Still having problems with scalding hot water. Have had thermostat on tank changed, 3 port valve changed. still no result and getting desperate.
Does the boiler have a thermostat inside? Could it be the boiler at fault?.
The boiler is a potterton promax, pump is wilo gold 80, valves are drayton x2 and a honeywell for the hot water (replaced a previous drayton).
Immersion is not switched on.
Have been told by an engineer that the pipework seems wrong for the system - there is a pipe leading back to the bottom of the hw tank and he couldn't understand why this should be? If this makes sense. I have added picture to try and help.
3 questions
Why is there nothing stopping the water reaching too high a temp?
Why do I not need to turn hw on when ch on????
Could immersion be interfering with system (have never used immersion)
You dont have a three port valve, you have 2*2 ports.
Which one was changed?
The pics dont really say much because there is nothing to show which one go/come from/to.
