Just installed a new DHW flow switch and microswitch on my Potterton Puma 100 as the diaphragm was passing water and had corroded the whole thing and shorted out the boiler. Install went OK and HW works fine now, but I notice that if I open and close a cold water tap quickly then it moves the diaphragm and cycles the microswitch and burner just for a split second. I can't imagine this is good for the boiler? I've checked the gap between flow switch and microswitch and is OK. Does this mean my DHW expansion vessel is faulty?
