I have one of the above central heating boilers. It has the problem that whenever you run the hot water, then turn the tap off, the pump stays on and after a few minutes the system makes an audible bang and gurgle and the 'Lockout' light switches on and it is necessary to press the reset button in order to get any hot water again.
This is a long running problem. I have been able to temporarily solve it by getting the air valve and flow switch changed. I then get about 1 year's use out of it, before the problem returns.
I would love to find a solution that will last, that is preferably not buying a new boiler. Any ideas?
It may or may not be relevant that the boiler is situated in a fairly small cupboard, but with vents at top and bottom (a reputable plumber installed this).
