Hello, Our boiler is a Potterton Statesman Flowsure + Combi boiler.
A few days ago woke up to cold radiators Checked boiler and boiler temperature gauge was showing boiler at 90deg (it usually runs at 65-70). When I moved the diverter valve arm to manual position, radiators got hot but boiler was still controlling at 90 deg. When valve arm was moved back to auto rads went cold eventually and boiler was still at 90 deg. Burner would cycle much more frequently than normal to keep everything at 90deg. Boiler temp control knob didn't have any control of the boiler in this condition so I replaced the boiler thermostat but this hasn't changed anything. I'm wondering if some other thermostat has failed to cause the boiler to drive to 90 deg.(Heatstore stat or tank limit stat?). I replaced the diverter valve actuator about 3 years ago, so I would be surprised if that had gone again. Something has changed to make the boiler run hotter. Can anyone offer any help please.
